Race pipe Installed- No 20whp !!
M3_Zoom said:
Maestro, I agree and I hope I wasn't coming across the wrong way. Actually I'm a very big fan of aftermarket parts however, if a manufacture is going to produce there own line of products that perform well, I'm a buyer. I have witnessed first hand the whole "your performance part just voided your warranty and we will not cover the repair" but, I also witnessed the entire court case that was filed against the dealer and manufacture. Fact is, by law you can install any aftermarket part on your car and the dealership must prove the aftermarket part caused said name part(s) to fail. This particular case had a manufacture engineer called upon and well, the end result was the dealership lost. This was only on this particular case so I don't want to be called out for being that guy that said xyz...if you know what I mean.
Gotcha. Warranty is a good thing to keep in mind though, especially when you consider what a pain in the @$$ it is to fight for sometimes as well as the monetary costs.
Hoping to test a race/test pipe in the next few weeks myself.
When it comes to warranty issues, remember that you have to pay to play. If you increase the boost on your motor and blow the motor. Or if you mod the motor, make big power numbers, and then have the tranny go out. Don't cheat and try to get Mazda to warranty it. In these circumstances, the motor or tranny were not defective. However, a dealer shouldn't deny a claim for let's say your A/C just because you have an intake or an exhaust on the car......
yakov456 said:
Whats going to be the estimated price on that ms exhaust? I actually am pleased with the stock one.
So far the best price I have seen is $590 shipped by our friends at Tonkin Mazda.
I heard a possibility of release end of this month, start of next. Hopefully somebody has newer info.
It all depends on the mid-pipe issue Mazdaspeed was having. It could be next week, next month...
Ron Tonkin has been a great vendor. I believe Josh over there said the final OK was given for the MS CBE and it should not be too much longer.
Why don't you all grow some balls and spend some money on some kick ass mods... :P
hmmmm cool mods...... my new CAI is kick ass!
Josh is GREAT!!! I'll have to give him a call today.
Update on my exhaust. Again this is all feelings based as I have not dyno'd BUT it seems as if either the power is back or beyond. It has been 5 days since the install. The first few days there was a definite loss in torque. This morning i got on it and it felt like it used to and with a little more zing. I disconnected the battery at the original install to clear out the computer but it had no inital impact. Does the ms3 learn on the exhaust changes? I was expecting it to be instaneous. It seems weird but I know I felt more torque. I also have been studing my shifts which now occur around 6400. I may have to take back my earlier comments if i continue to get this level of performance.
With a turbo car anything that creates better flow either in, or out of the engine will result in more power (assuming you can add enough fuel for the new air).
The concept of losing back pressure, managing exhaust pulses, exhaust system scavenging effects, etc don't apply for turbo cars. The little spinny dohicky after the engine exhaust ports pretty much ensures that the air in the exhaust is one smooth flow with no pulse effects left.
The only way I can see something like a mid-pipe losing power is if the flange size is so different that it creates turbulence and increases back pressure.
As j'sspeed3 said, yes your PCM relearns however, I'm still not sold on the test pipe. Turbo XS dyno'd it at 22HP and 30ft/lbs of torque with an CAI and Bypass valve. You can obtain that with just a CAI. Just my .02 cents
Also you need definitely change your shift point. The throttle plate is electronically controlled and starts to close at 6000rpms. That is one issue the aftermarket computer mod companies are trying to overcome.
just out of curiosity.. where do you live.. because here in NJ its been around 80 all week except today where it didnt reach above 55.. this change in temp will make a turbo car feel much faster.. dont mean to be a downer but my car is still lacking the torque...
Good point. I was thinking about that too. I'm in Nashville todays temp was a high of 77. These things are very sensative to temperature!
Its not a downer I want to feel good about this pipe as i have already spent the money.... I also want to know that it was beneficial and not some BS.
I hear you on the shift point. I mentioned that as it seems that i now have power up to that point. whereas before the exhaust I had no power. Just commenting on where the power now fades. Can an exhaust change the shift point? I've seen on the forum where 5500 was max..
Ryz said:
When you open up exhaust you usually loose low end but gain HP.
Perhaps when you are not in boost, but once under boost whatever helps the air flow better will help make more power.
You can't apply exhaust rules for NA cars when dealing with FI cars. Best exhaust for a turbo car is none at all.
rob142sti said:
so youre telling me if you run open turbo (no pipe at all after hotside) youll have more horsepower??
Yep that is the general rule for turbo cars. Here is a quote from Shiv at Vishnu on an exhaust system he designed for the BMW 335i.
"The reason we went with a fully divorced system is that they sound better, imho. And they should also make a bit more power due to less backpressure/turbulence. H or X pipes make sense in naturally aspirated V8s since they are used to smoothen out the exhaust pulses and make things quieter. In the case of a turbocharged engine, the turbine wheels themselves do all the pulse chopping. The goal of the exhaust, from that point on, is to make keep backpressure to an absolute minimum."
Not everyone likes him, but he makes a valid point about exhaust design for turbo cars.
