Quick Rims Question, NEED IMMEDIATE HELP
mobius120487
The Stig
2013 Mazda CX-5 Touring AWD
So i need new rims, bent mine, i have a guy sellin me some, he says new from a 2010 mazda 3, says they are 215/55-17 size, i know mine on my 07 3 are 205/50-17, will these rims fit my earlier model 3????
i know those are tire sizes but the difference in the width by 5 shouldn't cause any issues, should it? Does the rim need to be a different size for the change in width? Both are 5 lug design, i just wanna make sure these will fit on my current and not rub
Those tires are taller and wider than stock, if you arent dropped you might be able to get away with them, but they might rub over dips and such. It would be better if the tire size was a 50 series not 55. And you provide no information on the wheels, so I cant tell you if they wheels will fit, if they are oem mazda3 wheels, they will fit no problem
fixed, was able to find a oem rim that was the same year model, so it matches and got the same size tire to match the rest but it is a different tire, hankook ventus v12's with one yoko s-drive, now
