Prototype in Process: NSN Motorsports Manual Transmission Cooler
TurfBurn
'01 Yellow MP3 #1026
Hey all,
Some of you have heard about my little side project... but I figured i'd anounce it more directly.
I have been working on compiling and fitting my car with a full manual transmission cooling system that will be compatible with heavyweight transmission fluids.
The reason behind this is that there is a lot of potential benefit by maintaining reasonable gear oil tempereatures and increasing fluid flow over the gears in side the transmision. Additionaly, for those that don't believe that manuals create much heat I can personally vouch for the fact that I've boiled fluid out of the top release valve on my car under racing conditions. There are other vendors and experienced members as well that can vouch for the potential need for our transmissions to have cooilng added.
With that said, the prototype should go on this week (just waiting for a last parts shipment) and then will be available to the public shortly thereafter. It appears at this point that the kit will run about 350 dollars and that will include the 2 gph oil pump, -8 SuperStock hose, all necessary fittings, hose ends, and fasteners. The kit will feature an intercooler like bar and fin oil cooler that is a 10 pass cooler with a thickenss of 2". The cooler will be mounted underneat the "tool tray" in the front grill and allow for additional flow to enhance the cooler performance. all of the parts will be ready to go and included in the kit with full instructions.
Additionally, we will be recording temperature changes and running various tests to ensure that this is an effective solution and to provide data for the curious as well.
Kit Contents:
Tilton 2gph Oil/Differential Cooler Pump
Earls 10 pass oil cooler
-8 SuperStock Line
4 -8 hose ends
2 adapter fittings to attach to the transmission
2 angle fittings for in and out of the pump (-8 optional)
Mounting brackets
Fastenters
Instructions
The price should be very competitive to or cheaper than anything you can assemble yourself. The pump alone typically runs just under 200 dollars.
I'll post pictures as things are developed, but you can check out our new website which also lists some of the components and so forth.
Prototype Testing Results:
Car warmed and driven for 25 minutes prior to start of test w/ cooling system off.
12 mile stretch of road used for test runs, repeated boosting and acceleration/deceleration. 9 runs per pass:
Temp prior to testing start - 117.8F
Test Run 1 w/ cooling system on: Peak Temp - 120.6F
Test Run 2 w/cooling system off: Peak Temp - 134.4F
Cool down driving w/cooling system on following run 2: 118.6 after 7 minutes (120.9 after 1 minute)
Thanks!
Steve
www.nsnmotorsports.com
Here is a shot of the pump mounting bracket and the mounting location on the driver side under the car.
is an auto version possible?
any ideas on where I can get a performance torque converter too?
We already have an automatic transmission layout for the most part... I'd have to rebuild it and price it as there wasn't much interest in it... but it was like 80 bucks with the cooler, fittings, hose, and brackets.
ChopstickHero said:
very cool idea. any plans for an oil cooler kit?
Not really... the MSP cooler kit does a pretty good job by itself.... but it would be super easy for us to do an air to fluid cooler for the engine oil... there are a lot of ready made kits out there though... so I'd probably just carry the straight oil cooler kits that are already sold by many of the bigger names in coolers.
Sweet deal... any pics of the core mounted up? You say it is going under the tool tray, so are there any possible fitment issues with the DG grill?
I'd have to look at a DG grill... if anyone has pictures of it that would tell me... but there will be alternative ways to mount it... in all technicality the brackets should allow for it to be stodd off of the front bumper, but then you'd need to pull the bumper cover etc to do that part of the install... also, I may be able to make it so they work on grabbing off the front cross member where the radiator mounts to etc... but the pocket of space needed should be there without issue in both cases... it may require a slight trim to part of the stock grill... but it should be a minor thing...
I'll have installed pics as soon as the last parts come in (hopefully tomorrow or Thursday) and then everything should make sense :)
Later!
Steve
