M mp51987 Member : mazda protege5 swagon May 4, 2014 #1 Will the jdm protege5 motor slap right in a protege5? I need to buy a motor and was wondering.
W Ward83 Member : 2003 Protege5 May 4, 2014 #2 Yes, it will bolt in fine, it's the same engine externally. If I remember correctly, the only differences are the ECU, and camshafts.
T tweety2300 Member : 2001 mazda protege mp3 May 5, 2014 #3 Ward83 said: Yes, it will bolt in fine, it's the same engine externally. If I remember correctly, the only differences are the ECU, and camshafts. Click to expand... Ecu, cams, pistons, intake manifold, header, and most sensors are different You will need to use the USDm intake manifold, crank pulley, crank position sensor, and knock sensor
