Protege Part Out....(Suspension,Header, DaveB rings, TWM SS,....and more)
Status
Not open for further replies.
Mazda MP3
So the time has come to sell off all the parts from my MP3. All parts are used unless otherwise stated.
All items have shipping included for the continental US. Hawaii or Alaska may need to add a couple dollars if item does not fit in the flat rate boxes. For now I am not shipping to Canada, but I may reconsider come next week.
As far as payment methods, either paypal or local cash pickup. PM me for the paypal address. I usually am able to ship the item out next day.
-Enkei RPF1's 16in rims with Falken Azenis RT615 tires (tire size 215/45/16). 850 shipped or local pickup minus shipping
Had these for about 2 years. Only used them for auto-x. Rims are in perfect condition, no scratches or curb rash at all. Tire and wheel weight is 34.4 lb total. An amazing set for anyone doing auto-x or track events. The size of the wheel is 16x7 with 43 offset. The wheels have 67.1 mm hub rings (making them "hub centric") and I am also including the aftermarket lugnuts. The rims themselves weigh less than 14 lbs each. I do not have any centercaps, but you can find them online or on ebay if you like.
-Schroth 4pt harness 70 shipped
-NRG Grounding Kit 30 shipped
-Adjustment pieces for alternator (used to adjust tightness of alternator belt, if your old one is rusted it probobly is seized) 10 shipped
New in dealer bag. Never used. Purchased from dealer.
-P5/MSP/MP3 front bumper SOLD and shipped
New OEM front bumper. Never used, comes primed already. A little dirt, but in great condition.
-Din 3 guage holder
SOLD and shipped
-MSP shift knob SOLD locally
-OBX Header [/B] SOLD locally
Painted with DEI black high temp. paint and then wrapped in DEI header wrap. You can remove it if wanted, no problems at all.
-Brembo OEM front rotors SOLD and shipped
NEW in box. Never used. Purchased from Tire Rack but never installed. Work on MP3, P5, and Protege ES (possibly others also, but you need to confirm). Will NOT work with MSP. Part number 25349
-Espiler Springs SOLD and shipped
Some paint chips peeled off, but otherwise good condition. Springs will work for both P5 and Protege Sedan. About 20,000 miles on them.
-Tokico Illumina Struts 275 shipped
SOLD and shipped
Struts in good condition. They are a bit dirty from the dust under the car but work perfect. 3 of the struts have the little red tabs missing which shows what level the strut is adjusted to. I have marked the levels with blue tape and you can later mark them on the strut or however you would like. All are currently set to level 1, and all adjustments work. About 25000 miles
-Leather shift boot and e-brake boot SOLD and shipped
Bought these from a vendor here a few years ago (I think Redline boots or something?) One is for the shifter the other for the e-brake. Both have a little sun fade on them, but can be restored to like new with proper product. Both made from real leather with silver stitching.
-Dave B rings SOLD and shipped
These are originals from a special 2nd batch that was made for a short time. They are the brushed version.
-TWM short shifter SOLD and shipped
-Prosport gauges: Oil temp (comes with sender) , oil pressure (comes with sender, but you should probobly get a new one from prosport), narrowband A/F with volt meter , ALLSOLD and shipped
-Oil filter adapter plate SOLD and shipped
Comes with rubber seal but you should probobly order a new one from prosport
-RR Racing lightweight underdrive pulley SOLD and shipped
Lightweight and a bit underdriven. One of the slots has a chip in it from being removed, but that should not effect anything as you can see in the other picture.
-AEM Wideband SOLD and shipped
Used for about 2000 miles, great condition, comes with 2nd faceplate
-CAI w/ AEM dryflow filter SOLD and shipped
Has some scratches on the portion that goes into the wheel well and a small hole due to rubbing due to a bad bolt. Seems to be a simple fix.
-AWR rear endlinks 20 shipped SOLD and shipped
I only used them for 6 months, but it was over winter and as you can see they are a bit rusted on the outside.
Reserved 2
Reserved 3
pm'd on wb
Edit: WB sold!!! I forgot to ask who are you using to ship it out?
Payment Sent (Unique Transaction ID #9ND18274F22488134)
Interested in the oil temp and pressure gauges, and the adapter plate. What series are the gauges?
The gauges are from the prosport performance series 52mm. They can be set to display an amber color or white (even red, if you change the wire set up). The narrowband + voltage gauge is from the digital series 52mm.
PM'ed for payment info...
Status
