PRIMARY O2 wire placement?
Kooldino
MOTM Winner Jan '09
Authorized Vendor
Contributor
MP3
I'm a little worried since the wire for my primary O2 sensor is dangerously close to my manifold and wastegate. It hasn't melted YET, but in the meantime I wrapped it in aluminum foil, but that's just a temp fix. Where did everyone else run theirs? Or did you extend them?
dino, im going to send you some info tommorow on a great wrap for all those connections that are near the turbo and manifold to help keep the heat from penetrating.
I had the same issue. Left it that way for a month and a half and only recently extended the wires to kind of "clean up" the engine. I also riced the engine out a little (colored hoses and such). I'll have to post pics when I return from my business trip. (I'm just happy I can access the internet with my work laptop. I still get to read all the stories. Cool.)
igdrasil said:
hey perfworks, share the info with us too!
go to www.koolmat.com
or call pat pennington phone number 704 662 9000.
they have the best insulating wrap on the merket that if you do it right will last the life of your car and look good too. they have sparfplug wire boots and some big enough you could use as an insulator for your O2 sensor.:D hope that helps. i will be using that stuff on my setup soon so my pics will show it.
