OK.... my drivers side headlight has to have the headlights cycled a couple of times when cold to get the light to come on. Tonight, I noticed that when I turned the lights on, the drivers side came on for a split second then off... did it twice, stayed lit the 3rd recycle. Why do I have to cycle the switch to get that drivers light to boot up. Ive double triple checked all of my connections... Thanks.
Try purchasing/installing an HID relay harness. It's a good safe measure since the HIDs are take a good amount of power upon startup. Ever since installing mine, my HIDs always turn on with no flickering. I purchased mine from this seller on eBay. He has great customer service:
Ok, I sprang for that harness. Is there a diagram on what goes to what? I thought about the harness when I put them in... I need a piece of mind... Lol
Do a Google search for HID Relay Harness install or check on youtube for install videos. Or you can wait for the harnerss to arrive as it has a good install sheet. He has two different kinds of relay harnesses for the H7 bulb application. You may get one where you need to ground two wires to your chassis (I used two bolts up by the radiator on each side) or you might get one where the ground goes to the negative terminal of the battery. Feel free to PM me when you get your harness and I can help you out. Can take pics or shoot a video if needed.
