pics of my blown motor
SPOOND
2002 PROTEGE 5
this is where the rod came through i think lol
Is that on the back of the block?
That looks so familiar :(
Hope you get that thing back on the road soon!
here are more
/members/SPOOND/im001055.jpg/members/SPOOND/im001056.jpg/members/SPOOND/im001058.jpg/members/SPOOND/im001059.jpg/members/SPOOND/im001061.jpg
well really there was six hole 1 gigantic 1 on the front 1 big 4 little on back but it also broke the timing cover both parts of the oil pan and bent all the valves on the cylinder over all it was about $9000 if i would of bought stuff from mazda
damn, $9,000?
I remember when I spun a rod bearing on my V6 Probe GT. Shop said $3800 to rebuild the motor. I said "How much to drop in a new motor?" Guy said "$450". So $400 for a junkyard motor and $450 lablr. That's $850 compared to $3800. :rolleyes:
NoahFex said:
damn, $9,000?
and a motor that you dont know if it was beat on or not. It is a good solution to your problem, but a rebuilt motor would be like new.
-B
-B
Rebuilt motors only cost like $2,000. So $2,000 + $450 still is a ton cheaper.
i have a t3/t4 stage 3 57 trim 63 ar on a bone stock motor i was running 10 pound but when it blew up i was only at like 3 psi it pulled the threads of the rod stud
but know i have ordered 8.5-1-1 pistons and pauter rods from perfworks and got a copper headgasket from ddog777 also got spec stage 3 clutch and flywheel im trying to find some one that makes good cams and valves and springs
at 10 psi on a turbo the size of a t3/t4 your problem is not so much internal strength as it is timing and fuel supply - consider perfworks new engine management system he's working on with wagner.
Now that's some tensile stress! (wow)
You got me a little worried now. I have the same turbo except with a .48 A/R. I've been running 8PSI and now problems, but was thinking about going to 10. I'll stay where I am until I get my second motor built in the spring.
Are you doing anything to the trans? The stage III you have might be a little harsh for our drivetrains. I have the stage II and the guy at Spec said that would be the best until the trans is strengthend.
