DTC P0140 HO2S (rear) circuit no activity detected
DETECTION CONDITION
PCM monitors input voltage from HO2S (rear) when the following monitoring conditions are met. If input
voltage from sensor never exceed 0.55 V for 30 seconds, PCM determines that sensor circuit is not
activated.
MONITORING CONDITIONS
Drive mode 3
Following conditions are met:
Engine speed is above 1,500 rpm.
Engine coolant temperature is above 70 C {158 F}.
Diagnostic support note
This is a continuous monitor (CCM).
MIL illuminates if PCM detects the above malfunction condition in two consecutive drive cycles.
PENDING CODE is available if PCM detects the above malfunction condition during first drive cycle.
FREEZE FRAME DATA is available.
DTC is stored in PCM memory.
POSSIBLE CAUSE
HO2S (rear) deterioration
HO2S (rear) heater malfunction
Leakage from exhaust system
Open or short to ground circuit between HO2S (rear) terminal A and PCM terminal 35
Insufficient compression
Engine malfunction
