Did a drain and fill about 6 months back on an 03 Protege with Valvoline Max Life, (Dextron/Merc). I had called a few shops and they said that would not hurt it but now I am thinking that was very wrong. The manual says to use "M-V" which is Mercon 5 and I think this is a Ford Transmission. I just noticed that it is starting to very seldom Missshift. Anyone know if I could have damaged the transmission, (I did a drain and fill), and what I should do to get the correct fluid in? Do I need to flush it or can I drop and pan which apparantly get 5.7 qts out then drive for a thousand miles or so then do a drain and fill.
I hope I did not ruin the trans - I was trying to be pro-active on the PM side of things.
Thank You in advance!
