Need help locating horn fuse and relay 2004 Mazda Demio
I have looked under the bonnet and near drivers side panel and behind glove box and can not see any fuses or relays for the horn. Also no mention on fuse diagram for this model (DBA-DY5W), have checked the wire connected to the horn and tested the horn on a work bench which are both fine so guessing it's a power supply problem. So any help would be greatly appreciated.
Try left hand side of the dash
Mazda normally have the fuse box under the hood left side and same left side for the other fuse. location near left door you will or should find side of the dashboard
