mazda_sp20
- Mazda 323 SP20 (Australian FS-DE Protege)
Hello everyone,
I have tried searching everywhere for this and couldn't find an answer
I need to buy a set of ARP bolts and nuts to bolt on a new ring gear (crown wheel) onto my mazdaspeed LSD
I have purchased a second hand gearbox that has a 1-4 par straight cut synchro set and mazdaspeed LSD that was supposed to be in good working order.
The gearbox didn't feel ok and was hard to turn over after I bought it. After I washed the gearbox I found a crack in the bell housing. After disassembly we found stripped teeth on the diff ring gear and damaged pinion gear.
I have purchased a standard gearbox with damaged gears with a good case and good crown wheel and pinion.
I have stripped both diffs and separated both ring gears from the diffs.
I need to order and purchase the ARP bolts that everyone uses.
Thanks for your help in advance
