Just purchased a new Wideband, from Innovate.
Seems to work perfectly, while driving I hover right around stoich (14.7 parts air to fuel).
But when my boost gauge gets past 0psi I go INSANELY rich, I will regularly see 9.4 - 9.6.
Can someone please tell me this is not normal? I believe to have an unflashed ECU
psi ~7
I just leak tested 5 days ago... and its pretty solid (minus leaking past cylinders)
I was also talking to jdwk, and He says that while in boost it is abnormal for me to be going rich at lower rpms (should wait for 4200rpm to richen up)... is this true?
Any rpm in any gear, if I go above 0psi i drop down to 9.4-10.1 AFR...
Does this sound normal? It would be how I would think it should function though...... but just not that rich.
Mods should be in sig.
Thanks,
-Kyle
psi ~7
Thanks,
-Kyle
