Idea..... ?
It can also be dust in the gas...
have you put more fuel since then ? Try it, and put some gas
cleaner in your gas tank too.But before putting more gas, be sure
to empty this one first, just by cruising normally. I had that kind
of problem with one of my older ride.
1. I thought that was what the fuel filter is for?
For answer read below and skip all this part in the middle
Here is my .02 worth.
1. It's the CPU on the car. It takes time for it to LEARN it's
drivers habits and power curve. Someone already mentioned
doing a flash of the CPU, this is possible, but not necessary
IMO, just take the negative cable off the battery overnight and
hook it up in the morning. The CPU will be reset ' ish.
Here is why...
1. You know you don't step on the GAS peddle right? You step
on the AIR Peddle, it's called the mass air flow sensor. So the
CPU is learning how to react to YOUR driving habits.
2. Reason: Getting a race mode CPU installed / 'upgrade the chip'
You'll be amazed at how many freaking settings there are in a CPU
for just a car. LOL! "Just a car!" I think my car CPU has more
settings than Windows 7!
3. 75% of most car owners never feel a change when they use
different octane gas, add a 1,000 trailer to the back bumper or
pull a boat, the CPU LEARNS how to adjust for the towing, braking,
climbing hills, etc.
There are many reasons to step on the AIR, the CPU remembers if
you steeped on the air for 12 seconds last time or for 2:45 seconds
up some huge long hill.
There are many reasons to step on the AIR and NOT have the CPU
remember it, i.e. when you're in neutral, or park because there is
NO resistance and the RPM's just whip up to 8K and then meet
the governated limit and fall back down.
NO YOU CAN'T BLOW YOUR ENGINE BY PRESSING ON THE AIR PEDDLE
WHILE IN PARK IN YOUR DRIVE WAY UNDER 5 MIN! THE CPU WILL
LET YOU SIT AT 6K OR 8 K what ever you're programed for AND SIT
THERE AND JUST REVE THINKING "WHAT AN IDIOT WASTING GAS."
YOU'LL NOT BLOW THE ENGINE!
SO DON'T PEOPLE ASK: Why can't I blow my engine, I step on the
AIR and it goes to 8 K and no higher, why is that?
Because it's called a CPU in your car, it keeps dumb people from
doing DUMB THINGS. (inout)
SO in your case, I believe it's the CPU trying to run a process of
TURNING OFF THE A/C, checking to see what gear it's in and other
things, and it just takes a few seconds, plus you are used to your
other car, not all cars are made the same, hell not even the same
make and model cars are made the same, I bet I could go get in
another Mazda 5/Premacy and drive it and it WON'T feel like MY CAR.
See if the dealer has an updated software for your make, model,
specs, etc. If it's used, did the last guy have a tailer hitch on it,
haul buig loads in the back, or did he/she get the CPU mapped for
winter driving? It's the CPU learning YOUR driving style is what I think.
NO it's not going to drive like you old car.
There are many reasons, but hope this helps clear some things up.
Peace!(rei)
