Marko's MSP
2003.5 Laser Blue MSP
Marko's MSP
--Background--
I bought the car back in 2005 with 25k on it, and for a good deal at the time. I was always a fan of the MSP form the day it came out and always knew I would own one. I couldn't be happier that I bought it and still have it today. Its different and unique in more ways than I ever thought imaginable, and that's why I like it.
--The Goal--
The MSP build is focused on it being a fun/quick track car, but with the ability to still be street driven if I want. I don't really care much about straight line speed and max power, but rather a very well balanced car.
--Current Engine Mods--
-Custom Intake
-Perrin FMIC
-Greddy Type S BOV
-Stock Intake Manifold Ported and VICS/VTCS Removed
-Garrett GTX2867 Turbo
-Tial MVS Wastegate- water cooled
-SteedSpeed T3 Twin Scroll Exhaust Manifold
-Custom downpipe
-Custom 3" S-Pipe back exhaust w/ Vibrant race muffler
-Jay's Racing Fuel Rail
-Seimens 550cc Injectors
-Walbro 255lph Pump
-Aeromotive Fuel Press Regulator
-Microtech LT10 EMS
-J&S Safeguard with Bosch Knock Sensor
-Integral Performance 268/268 Cams
-Kasmankk Adjustable Cam gears
-Focus Adjustable Cam gears
-AWR Radiator with Fan Shroud including 12" Spal fans x2
-Samco Coolant Hoses
-Stant Lower Temp T-stat
-Weapon R Coolant Tank
-Doc B Racing Oil Pump
-Doc B Racing Oil Pan
-Doc B Racing External Oil Pressure System w/ Petterson Oil Regulator
--Built Block--
- Pauter Rods
- Arias 8.5:1 .20 Pistons
-ARP Head and Main studs
--Speed Circuit Built Stg 2 Head
- Ported and Polished
- Knife Edged Intake and Exhaust ports
- 3 Angle Valve Job
-Supertech Valve Springs and Retainers
-Signature Custom PVC Eliminator Kit w/ dual catch cans.
--Current Drivetrain Mods--
-OEM Differential- Welded
-Spec Stage 2+ Clutch
-Fidanza Flywheel
-Neo Trans Fluid
-AWR Front and Rear Motor Mounts
-AWR Driver & Passanger MM Inserts
-Kartboy Short Shifter
-Kartboy Shifter Bushings
-Kartboy Exhaust hangers
-Corksport Shifter Bushings
-Corksport 3rd Link Shifter Bushings
-Corksport SS Clutch Line
-Stoptech Slotted Rotors
-Hawk HPS Brake Pads
-Goodridge SS Brake Lines
-H&R 15mm Wheel Spacers
--Current Suspension Mods--
-AWR Coilovers w/Bilstein Shocks
-AWR Front Camber Plates
-AWR Rear Strut Mounts
-AWR Adjustable Endlinks
-AAC Adjustable Rear Link Kit
-GT-Spec Trunk Cage
-GT-Spec Lower Tie Brace
-GT-Spec Lower 4 Point Brace
-Corksport Front Strut Bar
-Pedders Front Control Arm Bushings
-Pedders Trailing Arm Bushings
--Current Misc--
-Volk Racing Wheels TE37 17x7.5 +40
-Custom Power Steering cooler
-Dave B Gauge Rings
-Black Face KPH cluster
-Greddy Profec II- EBC
-Apexi Turbo Timer
-Defi Boost,EGT, Water Temp, Oil Temp & Oil Press Gauges
-J&S Safeguard Knock/Retard Gauge
-AEM Wideband
-DG CF Arm Rest Cover
-XC CF Reverse Cowl Hood
-DG Front Lip
--Future Plans--
-Custom Fiberglass Front Splitter and Rear Diffusers
-AAC Front Control Arms or Custom
-Roll Center Kit
-Sparco Seats w/ wedge brackets
-OMP 4 point Harness
-Stoptech BBK
-Oil Cooler
-Trans Oil Cooler
-M-Factory LSD
-PAR Straight Cut Gear-set 1-4
-Better Standalone- AEM Infinity
-Plus other stuff I cant think of now.
holy s*** man whats left to do lol??? already a pretty much built motor, toss a bigger turbo on it and call it a day
[FONT=Arial, Helvetica, Sans Serif]Here is a little something to get this started.[/FONT][FONT=Arial, Helvetica, Sans Serif]
A little black and white action..
font
4882553988_dc2ec11f8c_z.jpg%E2%80%9D
[/FONT]
ok i have to post again, that is the most immaculate msp ive ever seen, how big is that picture normally?
i want it for my desktop background *wipes the drool off the table*
great build, great looking msp. impressive mod list like stated before get a bigger turbo and call it a day
Damn i wish i bought a blue one....absolutely beautiful
Great candidate for MOTM!!!
Sub. You need to post more pics, because you make me proud to own a laser blue :D
Soooooo nice and clean. Makes me want a DG lip again.
I literally tried to go through every part people commonly add and came up with this:
Thicker swaybars
Coolant catch can
505 intake mani (debatable b.c his is ported)
Wastegate actuator
Cf goodies
Lighter track wheel/tire setup than the rh's (although since hes running spacers makes me think he likes having the rh's nd wont be getting wheels)
So out of the handful of things that he could even consider doing, none are really necessary.
aside from stripping the car and caging it, e cant really make it a better track car.
This is the most complete msp that i have ever seen.
Well done on making, imo, the sweetest msp on the forum
Sorry guys nothing against your msps but this is sooooo clean and well done
He definitely needs a 505 mani, but that's about all for power mods. The ported stocker is about the same as a 626 without the crappy idle.
Similar Threads and Articles
