S SleepyMSP Member : 2003.5 MSP Mar 21, 2010 #1 as the title states I want to know if anyone has installed a MAM manifold using 45mm studs. I worked on one with 38mm studs and I know we needed to grind down one of them but will I be forced to do that with others if I use the 45mm studs?
D dandan2 Member : mazdaspeed protege Mar 21, 2010 #2 Not sure, mine didnt have threads so i had to bore out the turbo holes and use nuts and bolts.
S special--k Member : Mazdaspeed Protege Mar 7, 2012 #3 wow you posted this 2 years ago? holy s***! where did time go?
