Loud squeak going over speed bumps
Sway bar bushings. Best thing to make them not squeak is butt loads of synthetic grease. Or wait until summer :)
Seems like nothing is wrong with the car then. Good to know that. Are you still going to let the dealership change out your bushings?
well, now I'm not sure, I'd hate to have the car taken apart for no good reason. But it's not like I demanded it to be fixed. I just said it was creaky and if they could look into it, and shortly after I got the call saying bushings were on order.
Started having the same thing after I installed the eibach springs. Though I'm not sure if I drove the car in the temperatures below 20 before that. Today it was 8 degrees in the morning.
I think the important points to consider...
In the cold: If the noise goes away after a few minutes then it's probably normal. If it persists forever then it probably isn't.
In >32F/0C temps the suspension makes a little squishy sound when under heavy compression (e.g. speed bump). But I've only ever heard that with the windows open.
