Mazda didn't change anything to interior lights and license plate lights on 2017 CX-5. You can get those cheap Amazon / eBay LED kit for any CX-5 for your 2017's. Basically interior dome / map lights use 5 31mm Festoon LEDs、vanity mirrors use 2 fuse-tube type LEDs、and license plate lights use 2 194/168 replacement LEDs. I use this cheap eBay CX-5 LED kit for almost 2 years and have no issues so far:I believe i would need different types for various interior and exterior when converting to led, such as license plate lights, map lights, vanity mirror etc?
All CX-5 interior LED kit will fit 2016 MY. I use this 9-pc Bright White LED Lights Interior Package from eBay because they use newer and brighter 5730 rectangular LED chips:
I did install license plate LEDs from the kit. They look nice with white color and aren't brighter than original 5W bulbs. I also used two "spare" bulbs for reverse lights. They look much better with white color but the light outputs are not stronger than original 18W 921 bulbs.
I used this 2800K "warm-white" Festoon 6641 3SMD LED for vanity mirror on the sun visors for "warm glow" effect:
Personally I'd like to find 29mm festoon LEDs to match the original bulb length but those are hard to find for cheap prices and it's more difficult to put in 4 or 6 LED cells for brighter light. With 31mm LEDs you have to bend some end and side clips a bit but it's doable and won't hurt anything. Also be aware the "prying tool" included in some Amazon or eBay kits is useless! It's too thick and sometimes you're better off by having two pries to pop open the light cover. I use this prying tool set from China with decent results:
There're low-priced LEDs having 2800K color temperature which looks like the same as standard incandescent bulb but can be brighter. I found this 2800K "warm white" Festoon 6641 3SMD LED for vanity mirror on the sun visors for "warm glow" effect which looks the same as OEM light but brighter:
Hi,
I can recommend these as they are very bright and also comes in various colours: https://www.aliexpress.com/item/Hot-Sale-2pcs-T10-194-168-W5W-COB-8-SMD-1W-80Lumen-Silica-Super-Bright-LED/32692054812.html
They are easy to handle and I like the copper coated contacts on the PC board as well as the clear silicone coating. I have installed them on the licence plate lights and the longer ones on the reverse lights.
You can read this long thread to get a lot more info about LED interior light and license plate light replacement. Since you have a 2017, you can start reading the thread backwards as some 2017 CX-5 members have posted thier experience and LED technology has been improving. The hardest part is to remove the license plate light lenses but with the plastic prying tool I suggested you may have better chance to remove the lenses easier. Make sure to read the instruction in your owner's manual. And for 2017 CX-5 the reverse / backup lights are LEDs instead of incandescent bulbs in 1st-gen CX-5.Thanks. I'll give them a go. Any tips or advice?
