Just curious...
CRDMS1
...why nobody is using the Redline 75W90 Gear Oil in the Mazdaspeed tranny. From their website...
75W90 Gear Oil - the preferred product in nearly all car and light truck differentials, both conventional and limited-slip. 75W90 is preferred for most racing applications. It contains friction modifier which is recommended for limited-slip units. 75W90 Gear Oil can be used in many transmissions and transaxles; however, other Red Line lubricants have better frictional properties for rapid synchronization. Exceeds API GL-5.
Interesting that it specifically mentions a 'friction modifier' for LSD applications. I've seen threads recommending MT-90, MTL, and Shockproof but none of them mention anything about LSD.
Anyway, I plan to switch tonight and would love to hear your comments on this issue before I have to go pick up my fluids. I also will call Redline when they open...
Peace...(hippy)
haven't tried redline but amsoil makes 75w90 that is designed
to work with LSD,s. amsoil also makes an additive called SlipLock
in a 4 oz. bottle that you can add to any other fluid.
Redline is a well respected product in the synthetic/racing community and usually shows well in independent testing. I'm not sure about the Subaru issues, but several members of this site use their products with no reported problems that I can recall.
Back on topic!
Peace...(hippy)
Never mind. I spoke to a guy at Redline who kindly explained that the 75W90 gear oil with friction modifier is for the clutch-type LSD only (chatter). For our car, he highly recommended the MT-90 for daily driving with the occasional autocross mixed in. Picked mine up at lunch...$6.95 per quart + tax (case purchase).
Peace...(hippy)
Peace...(hippy)
What is the difference between the MT-90 and the Shockproof oils?
Without getting into all the technical stuff which I barely understand anyway, Shockproof is intended for long duration racing-type applications where the transmission sees much higher temperatures than normal. For normal spirited driving and occasional autocross or drag racing, I see no real added benefit over MT-90.
You can read all about Redline products on their website at:
Redline Products
Peace...(hippy)
