Just curious about your guy's mileage
hellcat said:
62,000 miles. I'm on my second engine, and working on getting the second trans. Had the primary cat go bad at about 35k miles. Oil filter mechanism failed causing the flow of oil to slow down, leading to crank bearing failure. Gas mileage isn't as good as it was. I need to do the egr clean too. Time for the new timing belt and all that fun stuff also. My third gear syncro started going out at about 20K. Mazda would not warranty it (I know you are shocked right?) Car is running smooth though. I still love it. Oh yeah, my struts are starting to creak when I go over speed bumps. That's all I can think of for now.
Hey Carl, I have a set of struts i'll sell you w/ 1100 miles on them. I'm outta minutes so text me you are interested.
32000
blown shocks due to tein springs
belt loose :(
grinding second every now and then
still a blact to drive :D
59k on mine, no problems for the year i have had it
must have had some tranny issues for the previous owner though cause the tranny case had a "remanufactured" badge on it
ke20sprinter said:
wow I guess I beat everyone
137,000 miles (though I only put in ~1,000)
Yeah, I've had mine since late august, and I've put 8,000 on it so far.......
02'.5 with 40,000ish miles, no problems at all what so ever, no rattles clunks, bumps or bruises. Even started right up after damn near a yr of sitting.
good to know
drove mine for 2 yrs put around 16,500 miles on it then totalled it, still ran fine after I flipped it.
25K on my '02... no problems except a bad drivers side rear strut.
ENTENSE said:
How many miles does everyone have on their P5? (any engine problems, if so what and at how many miles did the problem occur)
I have 27715 on my 02, haven't had any problems (knock on wood)
47,000 miles on a 02. runs great no problems well other than the fact its been side swipped once and rear ended twice
03.5 w/ 29k miles. Only problem I have had was the VICS screws and that should be being fixed right now.
If you don't mind me askin, how did you flip it Padanky? I have rolled over in pickup trucks, hard to imagine in a p5.
28000 in my 03 P5, no problems, but then they just fixed it up for me, just bought it @ 27k
First post!
26k in my 03.5. Bought it new just over 2 years ago. Biggest problem is the stock tires. I've curbed it twice in the past week because of the tires. Now I need to get an alignment done.
It's also rattles a bit when it's cold outside. I get clutch chatter. Other than, everything is great!
