I have the red neon's on both the driver's and passengers side. NO wires or bulbs showing. You can turn them on with a push of a small black button. I dont have pics right now, I'm at work and dont get off of work for several more hours. It looks good because my gauges are red on my dash and my boost from my pillar pod is also.
you can drill holes(making shure no lines are under where you drill!!!) and place them under sat on the floor...move the seats as foreward as possible so you cna see a spot where nobody can "Accidently Kick" them. or leave enough slack in the wire and zip tie them to the bottom of the seats...you usualy run the wire to a fuse in the cabin using a 2nd fuse and then anything metal is the ground.
