Indexing spark plugs
CHIQLES
Contributor
mazdaspeed protege #0403
Thought I would ask to see who is indexing there spark plugs and which orientation toward or away from fuel injectors what style spark plugs and gap size...
Im running pulstar BE1I PLUGS gaped at .025 facing injectors at within 25 degrees from center...
What is Indexing spark plugs-
Indexing spark plugs is when you face the electrode of the spark plug toward either the intake or exhaust valves, it is an old racing trick to try and get better performance out of the spark. This is usally done by using copper washer that are set at differnt thickness. Napa auto stores and some other retailers may carry these.
Why should I care about indexing, well if your like me I try to gap my spark plugs as close to each other as possible this is just the last step in order to get the biggest bang for your buck.. every hp counts even if its only 1 to 2% increase
