Hub Bore question!
Our hub bore is 67.1 so, you'd have to machine the wheels to get them to fit, spacers don't really apply to the hub bore, as far as I know, because the hub bore is used to align the center of the wheel and a smaller hub bore for the wheel would mean that the wheel won't even fit over the center bore of the ms3.
You can however use a wheel with a larger hub bore than the ms3 hub bore, people usually run hubcentric rings to get it to fit perfectly though.
well on my rx8 i had the same problem but with the spacers it brought it out past the hub so it was okay. i was hoping i could do the same on the speed.
Been almost 2 months since I've had the wheels off of my car. Take one off, measure how far the lip on the hub extends. You'll need a spacer to at least make up that difference. Of course after that you'll need to properly seat and torque your lugs since the hub will no longer properly center the wheel.
