HP difference between 2.5 NA CX-5 and CX-30
This question may have already been asked. But it's sort of bugging me to get an answer. Anyone know why the 2.5NA in the CX-30 has 4 HP more than the 2.5NA in the CX-5?
You couldn't feel a difference of 4hp between the two motors if your life depended on it.
I know. I'm not looking to chase small HP increases nor am I looking to modify my car to get more horsepower. Being the engines are the same between the two chassis, I was just wondering why the difference. It's just an academic query. Is it due to intake plumbing/routing? I also noticed that the engines in the CX-5 with cylinder deactivation are showing 1ft lb less in torque than the non CD engines. Just interesting to see the variations.
I checked the 2026 models and saw that the CX-30 had 1 less HP (186 vs 187) than the CX-5.
It was across the entire platform no matter what trim level. I tried to pull it up on Mazda's official site but they already pulled down the 2025 model info.
My guess would be different tuning maps for emission reasons. The CX 30 is lighter then the CX 5 so maybe they could tune it for more HP with same emission results?
The loss of 5 HP for the 2026 CX 30 could be because of the same reason: lowering emission ratings.
I do think there's some tuning stuff going on. I saw a video discussing Mazda in the Australian market and how Mazda is going to be in trouble meeting the emissions requirements. There was a mention about detuning the 2.5NA in the CX-5 down to 177HP.
I guess the tuning choices being made may also be influenced by global factors. Still interesting seeing the CX-30 being detuned for the 2026 model year for the US and I wonder why the CX-5 for the US wasn't brought up to parity with the CX-30.
The other odd thing about the CX-5 2.5NA with iStop/CD is it appears the 2026 model year cars gained back that lost 1 lb ft of torque.
It sounds like the 191hp output could be for a different market that has better quality gasoline than NA.
etc. older models of the skyactiv 2.5 had a higher compression ratio and made more power (191 vs 185) in europe vs NA.
Europe (or anywhere) has better quality gasoline than NA?!
The 191hp version in North America was used in the 3 and CX-30 from 23-25 model years. The engine has an egr valve, traditional thermostat, cylinder deactivation, redesigned intake ports, different exhaust manifold to support egr, different intake manifold with fatter runner cross section as well as tumble inducing flaps and a different exhaust camshaft. A different tune of course to handle all of the hardware changes, it also to me driven back to back has a noticeable bump in low speed torque.
usually if these cases it is the exhaust system..would be different on the CX30 vs cx5 so that would be my guess. less plumbing...be interesting to put both on a dyno and see what they really made...
