High Beams too high
aceblaster
2008 MazdaSpeed3
I'm having some problems with my high beams on my 08 MS3 and can't seem to find a solution...
Since I bought the car my high beams have been virtually useless as they shine nearly straight up... I have looked everywhere on the mount light itself and can't find anything that allows me to adjust the height.
Has anyone else had this problem or did I just get a retarded set of high beams installed on my car? Any ideas on how to fix it?
I know that with the sixes there is a way to aim them. You might wanna check into it whether you can do that.
Unfortunately, due to its inferior design, there's no way to adjust the high beams independently. The only way they can be adjusted down is if you aim the low beams - which in this case see Darth Vader's post above. So perhaps your low beams are a tad too high right now?
I know when I had my MS3, the low beam HIDs were even, but when the high beams were on, one was higher than the other.
So I can adjust the low beams but not the high beams? That other post explains how to adjust the low beams to get better viability. So in short terms, Use the Low Beam Rocker to change the low beams and use them as the high beams also?
Correct. You cannot adjust the high beams. Low beams can be adjusted two different ways. Either by using the nylon/whitish clear looking slot screw or the two adjustment screws. Basically, the lower the low beams are, the lower the high beams will be...and vice versa.
