HID's not as good as others
Brian MP5T said:
Sounds too complicatd. What happens whe one burns out?
i dunno! get a new bulb!? or you can just go with regular HID and nix the highbeam part...... (boom07)
But you understand what I'm asking, If there is a High and Low in one bulb and the high burns out... HID=Garbage Can
i know... makes sense .... hmmm... get HIDs for your fogs too .... super brizzzzite
I think I would get hid for the 944 before I did that.
The P5 Fogs are non functional. I remade the "Look" of the stock ones out of plexi for weight.
ChopstickHero said:
the P5 housings have no cutoff whatsoever! the Protege sedan housing H4 have a better cut off....
they have a cutoff... just a weak one at the left side of the horizon... not super weak like many domestic VO lights, but still weak
they ARE functional... as FOG lights... not DRIVING lights... the put light very low to the ground and only work good in fog... do the fog light mod and you can use them they way they were intended to be when there's fog
Brian MP5T said:
Sweet idea. I have however just tilted down a bit, I no longer get the Highbeam flashing...
Ive noticed that cars never flash me, but SUVs sometimes do....
Sweet revenge. (hah)
Dude, They are already gutted and they suck as Fog Lights too because you have to re-wire them so they can come on without the headlights..
No Thanks..
uhh the P5/MP3 fog lights are actually OK for fog lights... not GREAT, not GOOD, but OK... if you want to see BAD fog lights, you should check out the 3's
My Wife Owns One And It Had Been Noted...
I tried to talk mine out of it, but she bought one too. And yes, the fogs are pathetic.
Huh? Hold on, I couldve swore it was on the turn signal stick. Going to check....
Edit: ok, it is on the signal stick, is it a Canadian thing?
it is.... brian is smoking crack again
It's not my car man.. (The Man/Edwin)
I was just expecting the switch to be on the dash like mine. Never really bothered to **** with the buttons etc...
when i first got my 3 i thought you could nt turn them off either. a week later, i realized i didnt even have them turned on and quickly found the on off switch.
Monkey_3 said:
Stock:
Stock with washers:
With Evo8 lense:
With Evo8 lense and washers:
With Evo8 lense and washes and lense space mod:
S2K projectors (best in the market right now) fromt he same distance to compare:
WOW!! How'd you do that? Thanks for your reply...........last last 3 pics with the Evo8 lenses and washers, etc. is EXACTLY how I would like mine to be. I wouldn't dare try any of those mods myself...........but would love to have them done. Where do you suppose I could go get that done? At least I know there IS a way to improve them.......thanks!
