Yes, it does but getting my hands in that small area and using a socket wrench sucked lol. It is nice because they made a perfect groove that you can slide your screw driver through to reach the adjustment screw. I just used a long screwdriver.
Did the pwr steering pulley rub your hand when doing the passenger side while adjusting it? Mine did once so that's why I started doing the 1/4" drive ratchet/10mm socket thing on mine, lol. Yes, I drove to dark place and got out and adjusted using the pavement to make it hit where I wanted it and then drove around to make sure it was right when driving because the wall is just a starting point as far as I'm concerned. The motor is running whenever I fine tune most of my light adjustments. Even on the wall doesn't necessarily = even and straight up/down & side to side on the pavement.
Has anyone else had significant radio interference from the ballasts? I have mine on the inner fender and I get a lot of radio interference, even with ferrite cores between the igniter and the bulb. I'm using the Morimoto H1 kit with 35W Morimoto XB ballasts.
