HiBoost install - Greddy Type-S + BPV (no 56k)
muohio said:
Most newer sc's have a clutch to disengage them while cruising to increase mileage. People have also been putting on a set of LS6 heads and cam and seeing about a 70whp increase for around $2k. I'm more worried about making it through winter alive (confused)
Love that Ohio weather eh?! I do too. Winter tires and steelies on the way. As far as the GTO.....good luck in the snow!
i ahve that buffing attachment for the dremel and it spins quite fast, i think all i need is the right compound.
Well you have to press very hard on the heatsheild with the buffing tool. Don't know how this is done with a dremel. The buffing wheel cannot be too soft....you must get a dense wheel. The heatsheild should shine without the compund. You can almost get it looking like a mirror without the compound at all. The compound just adds a "chrome" look, but well worth it. It makes for a fine buff, and to be used last after the "rough" buff you initially did. I guess all I can say is keep it up. The buffing wheel should turn black while doing this. I am noticing my heatsheild slightly "browning"....so I will have to polish mine again. Good luck.
this may be a dumb question and way OT but out of curiosity, what would be the impetus for going FI with a SC rather than turbo in this case?
i was always wondering about supercharges too, im intrigued by the way they whistle and want to learn more about them
Typically, the LS1 engine produces a lot of heat, so a sc is a little more desireable. Plus, they are easier to deal with from a maintenance and install point of view.
I have mine at 10psi, with a 14psi spike. I'm afraid to go any higher than 10psi cause of the spike. I have all the supporting mods.
hello2000 said:
Yes you should reset the ECU. Any time you make a change to the engine to add air or fuel, you must reset the ECU. Hiboost says 12psi is safe, but I would say 10psi. I was at 12psi and I blew my engine. If you have upgraded the exhaust 12psi should be ok. If you have exhaust system, no higher than 10psi.
Yea I will set my level 2 boost at 10psi, and my daily driving at 8psi. I hardly use all of my boost anyway. I bumped it up the other day and accelerated fast....may max boost read by the HKS EVC was 9.3. It seemed to pull JUST a bit faster than the 7.8 it was reading before. I really didn't try it out enough. I can turn the knob a little more so I max out around 10. Thanks for all the input....car is running well. Wishing I had engine mounts....
Well, I've been studying this thread for this whole week and here are my results.
I welded a nipple similarly and in the same location as you did^
I placed the stock bpv in, facing the correct direction and ran it to my intake.
It started to get late so I tried to T-off the vac from my greddy and ran it to the bpv (instead of tapping in to the bb hose)
... And when I went for a test drive, I stalled horribly. Would tapping into the BB line Fix this? I'm going to try again tomorrow night. I would've taken pics but my digi cam ran out of batteries.
PLEASE HELP!!!
PLEASE HELP!!!
When did it stall? What exactly happened?
I am guessing there is a 'hole' somewhere after your turbo. Either a coupler is loose, or a hose came off a nipple.... I dunno. Once my BPV hose came off the nipple and I stalled whenever sitting still. I could start the car if I revved it a bit, but when the air flow was slow it would ALL creep out of the hole and I would stall. Also, tighten the Type-S enough to where you don't get the buck right as you shift. I think a little past half way (tight) is where mine is. I do not think tapping into the type-S vac source woudl cause stalling.... it shoudl still work, it just not ideal. Give me more details and I will try to help.
Also reset your ecu. Take off the pos terminal from the battery and wiat 10-15 minutes. Press and hold the brake. Put terminal back on.
You wont stall for not doing this, but just an FYI.
It started off fine, then as the more i drove the stall got worse. It even wanted to stall while I was standing still. I'm gonna check all the clamps, couplers and hump hoses later on tonight and I'll see what happens.
Thanks for your help.
No prob. Yea look for a leak after the MAF. That will cause you to stall just standing there. It must be a major leak though, to leak out enough air for your engine to choke. Check your vac connections too, make sure there are no leaks there.
I agree, I had the same problem when I first installed my CAI.
the only pipe i took out was my ic/turbo pipe. I never touched the injen. Can a leak on the turbo/ic pipe cause me to stall like this?
Yes, it is after the MAF. Again, it would have to be a considerable leak. Check your IC -> TB pipe as well. Small leaks can be found with carb cleaner or torch gas near the couplers, but small leaks will not stall you.
So it stalls when you come to a stop? Does it stall after you shift? Try to explain the nature of the stall.... that might help. I have solved about three stalling issues on my car since I have pwned it. :)
Right after I shift it want to turn off, and i have to fight with it by givinf it gas so it'll stay on:mad:
I just got back from my garage and I tightened and checked all the clamps and its still stalss wheni rev the engine. The rpms drop all the way down.
I can feel a little breeze comming out of the outlet of my bov. Is it supposed to do that? Should i try re-doing the vac to the booster hose? Would that help?
When it idles, you should feel no breeze. Make sure the Type-S is screwed down well, make sure the screw is on the hard setting (3/4 the way down). Even with the screw loose, it should still work, just not well. Its like you are not recircing any air....I dunno. You are stalling way too much. Is your MAF hooked up well? You would throw CEL tho. Hmmm... man just tripple check everything. I'm lost. Let us know if you fix it and what was causing it so we can all learn from your misfortunes ;)
Good luck!
56k warning
How does this set up look to you?
