Headlight housing removal ..
2017 Mazda CX-5 GT
Folks, I posted a thread about high beam replacements in the Accessories & Appearance forums, and it got me thinking of another question that I could pose. Has anyone actually removed the entire headlight housing here? I need to remove it to do my HID projector retrofit.
I checked the service manual and it states that pretty much the entire front end has to come off. This was the case as well with my old Tacoma, but I was able to contort and reach a little bit, and avoid the bumper removal. I'm just wondering if anyone has had the bumper off or removed the headlights and knows if it's at all possible to remove the headlights without removing the bumper.
Thanks in advance!
no you have to take the bumper off because there is a bolt under it on the side. If you dont replace the bolt, future removals wont require bumper removal.
Update .. You DO NOT have to remove the bumper entirely to remove the headlights. You only have to undo a few clips on the wheel well trim and the bumper itself. I was able to get the headlights out with only unclipping the sides of the bumper from the fender, and also the large clips that are clipped into the headlight itself around the grill.
Retrofitted Maxima projectors last night and blacked out the headlight bezel. Came out great! I'll have to get some pics later.
Pics please. How much of the mounting points did you have to modify (if any) for the Maxima projectors?
I don't have pics of the mounting, but you won't be able to go back to stock projectors, and I had to trim the outer portions of the projector shield as well to get them to fit.
I do have pics of the blackout though ..
HCRqpvDQaGPJ4c3Y3v9v5fOis1pEMX8LqY1TtF1CEmAX9DHG1TXcZl2k5PKLO5eVaHxThMYujVvkFFMmBLweSXF-TYrhmEkhk4ge5xI2Elx9dxyhKfXNqrAi2fGrzVDLHJTgHKuxkelGiPqd1sEsycDKFuxsIOcf0hoGxKkQ7umUKU7jgtK-m3_HA2BxCq5L2LL2qvaDwvwenoXhthqRL6vZewnVPPOujufM7QLkDACS4CMwxGOVYTk0MraBrP30eAARTuiSWZFg70OXEiDnt8P7u9Vf1CPgx0G5tzM_S8gsJ_RKpfTcyZb7-K7sErN05Buq2ZUmFgSxS6nCXJ93nyiPupBzXr4fB-3waJ4xMAJuK2CBOnM5-S2Ldm_dfC85apARjBRHXl76xEWPM5VHkIT8E-wbDAdL6UQrjcI0KnYE5so5s5wZwCCs2pqogKl281yIRKinHTUNhcLXRhE055lWbCtzUWMfHhNUsIPXBWQp9ZlYdvnqdBSm8q5P40b9P9onjwyNSqf2gOdR54SlYVjFR-IKREwATiKq4hK1fncS=w1384-h778-no
I'll get some better day time pics, as the wife had to take the car to work and I didn't get any shots of it yet with the lights in.
Pics not working. Either way, great to see someone put the effort in for proper (safe) lighting. I'm sure both you and all on-coming drivers appreciate it.
I'm interested in how the blackout housing looks, I'd like to match my fronts to my rears (including removing that orange reflector)... also after testing safely opening the taillight (the good one from my old pair) I will be taking that annoying red reflector out and putting the clear one in.
After doing a full Bi-Xenon retrofit in my Tundra, I don't want to drive anything with Halogen lighting, and doing the retrofit worked out great. Going to try the pics again ..
Couple more pics .. Tinted reflector and close up of sealed lights ..
Sent from my Nexus 5 using Tapatalk
Oh yes, that looks good. Real good. Was the disassembly difficult with the factory adhesive?
Looks good. IMO, some chrome amber bulbs would complete the overall clean and stealth look.
Not at all. Uses a type of butyl sealant. 250* for 8 minutes and they opened right up. Compared to my perma-sealed Tundra lights, these were a cakewalk.
Couple of front shots to try and show the black housings again .. and a shot of the rear dummy fogs that I tinted as well.
