Engine repair info.
mapa19
'91 Miata BRG, '95 MX-6 LS, '02 Mazdaspeed5, '04 Mazda3 S-w
I have a BIG question...
Has anyone taken the engine apart in the car? I need to replace piston rings, and idk if I need to pull the engine out, or if it can be done in the car.
Ideas?
I know. But idh a hoist, or the room to do a full pull.
I usually pull the engines at the shop, bring'm home, and work on'm at my leisure. But bj's at home, and idh a way to get it to the shop.
I'm a small dude, and I've done tranny swaps in my garage. I have HEIGHT, not side-room, so yea. LoL.
Can I safely drop the pan w the block in the car?
Need help urgent ? I have a 1999 mazda familia with the zl-ve engine, its was automatic and i change it to manual (problems):i am missing my airflow box the part that the filter goes on the bottom half (it was stolen) it had a burnt knock sensor ,blown head gasket around the compression rights,and the gas needle moves every move i make depends on the turn are what ever i have a problems on hill (not my driving skills)when the gas is low are on the first mark,and it has a flat spot on move off if i push in the clutch and rev it will take of then die down immediately then pick back up again. Can anybody shine any light on this matter are know how i should ask?
