Timmy_03-P5
- 2003 Mazda Protege 5
2003 p5, 114k miles, owned the car for a little over a year now:
About 6 months ago I noticed that I had lost some oil between oil changes (had fallen about a half-quart low it looked like), so I watched the oil level and coolant level to see if anything was getting worse. I replaced the PCV since some guys had had the same problem and this solved it. Seemed to help, but didn't get rid of the problem, so I figured I could limp it through my last semester in college, and rebuild it next summer when I had the time and funds. I haven't been losing any coolant, but between oil changes I had lost about a quart of oil (~3000 miles each). This was until last weekend I took a 250 mile trip, so I checked the oil before I left, and since I was about to change the oil before I left, I checked it and it was about a quart low…knew I was headed for either new valve seals, or maybe rings since the coolant and oil were still not mixing.
That is until this morning. I went to drive for the second time since I returned back from the long trip, and the coolant reservoir is empty and, of course, oil is all creamy…great. So I'm assuming head gasket, amongst possible other things? I was thinking of getting the engine rebuild kit from Rock Auto, the one with out the timing belt since I just did that a year ago. My step dad can grind the valves for me while I have the head off, and I just need to get this back together since it is my daily driver.
tl;dr: been losing oil for a few months, assuming head gasket has finally given out since coolant reservoir is almost empty and I'm looking for some tips and/or recommendations for beginning the rebuild.
Thanks for all of your help this time, and the past times I've posted.
