Electrical diagram ?
foxhound1979
Mazda 5 GS
Hi guys !
Don't know if any of you guys can point me in the right direction, i need the electrical diagram for the 1st gen 5.
The problem is that i don't have any low lights working and the high and yellow corners work fine. It could be my HID, but the electrical could come in
handy if the trouble is not related with my HID's.
My guess is : since the corners work, it's not related to the switch. I'm thinking a relay inside the fuse box or even my hid relay harness that froze in the minus 40's celcius we had a couple of days back. Even when the car is "hot", still no lights.
Thanks for any kind of help / input !
Have a great 2k14 guys !
I have a complete factory Maint Manual CD I purchased on E-Bay fro about 10 bucks.
A good investment. Being where your from It would be a good guess that you have corroded contacts. Check if your ground is good. I bet you won't need the diagram. What year is first Gen. Premacy has been around longer.
Good Luck
Thanks Donewood,
found the problem : a half melted fuse in the HID Harness..when it was hot enough in the engine bay, the contact was ok..when it froze again it lost contact. Everything works fine since !
The Maintenance Manual is on my next to buy list for my 5 !
