Compression WTF???!!!!
chdesign
OK the pro was feeling a little sluggish and i noticed a spark plug wire arching so i replaced though and that stopped but still sluggish did a compresion test and I got 123 on all four cylinders give or take 2 psi. Now according to my haynes manual the stock compression should be around 171 at 500 rpm i did the test by turning it over with the key. Now correct me if i'm wrong but isn't that number a little low???? but it was across the board so no peaks in compression and no weird variations so they should be ok no burning oil but still a little sluggish maybe its those heavy ass 17"s i have on there maybe i should ditch those for some ACE rims or the nice tri spoke advans. any suggestions guys?
Here is the info on Compression Check
Cited From Mazda Service Manual for 2001 Protege
ok redid it i forgot to hold the pedal all the way to the floor I got 168 across the board this time so I'm not worrying anymore.
