Alright, so after having my first clutch replaced 2k miles ago, tonight I starting noticing the clutch is squeaking again. This happens only at idle and when the car is completely off. It did this a while before my last clutch went out and now it's back. Any ideas? This is my first manual, so it may be normal, but I'm really paranoid now that I've already gone through one clutch in less than 12k miles.
So, again, it's a squeak noise coming from what sounds like underneath the car. It happens right before the clutch pedal is fully pressed down and stops. The car is in neutral, A/C off, at idle or off. You can let off the clutch just a bit and push it in again and the squeak will happen again. It almost sounds like a spring or something is somewhat dry or not getting fluid.
