I replaced my two front Struts/Springs/Top Mounts. What i did not replace was i used the old boot over the struts. I also did not replace the plastic piece that holds the springs on the struts(I'm not sure what that's called). Well, the problem is that once the fronts were finished, i hear a clunking noise from the passenger side. I hear it could be ball joint, Strut boot, stabilizer bar, Sway bar, Control arms or etc. I don't know what it could be. Then again, before having the original springs/struts/mounts removed it drove just fine, car is at 66k mileage. I'm not sure what it could be. My Driver side makes no noise whats so ever. It makes noise on bumps, turning, etc with the new struts and springs. I'm abit confused. I'm going to finish up putting on my rear ones on tuesday once the endlinks are loosened. The rear mounts were a PITA to get too, well at least in my opinion. So any help would be appreciated. I had already removed and reinstall everything and it still does the sound. I hope it's nothing crazy.
P.S: Are new Stabilizer end link bars required if it's a new strut or no? I heard I don't need any from a fellow forum member. Just want to double check. Thanks again.
