Camber links question.
schlepperock
07 ms3
Are they spring/drop specific?
Or could you run eibach links with hr springs?
Also do they go on the front too?
I plan to get springs and don't wanna toast my new tires
Camber links are for the Rear only....if your going with H&R's then you really should get them, unless your running some wide as rims/tires then some camber will do you good.
im running H&R springs with no camber arms. my rear camber before the drop was -2.3 degrees and after the drop was -2.5
i woulnt say they are absolutely necessary.
