CAI BOV/BPV Throwing Code?
I know you were saying you were getting a lean code, maybe a lean at idle code? Could you go get that re-read and give us the actual number? Also, do you have a boost gauge of any kind? Does it read vacuum? What is the idle vacuum reading (in inches)? Is it steady or does it wander? It will change a bit when your A/C cycles, but I'd like to know what the gauge is saying and what the actual CEL code number or numbers are.
I have an OBD reader I'll get it hooked up ASAP and get the actual code numbers. I don't have a boost gauge, is there a censor I could look at to get a boost reading through the OBD? It can read real time so I'll check it out.
And yes the code that is throwing is a lean at idle code but it was also throwing a lean off idle too...
Just Curious, when I put my PG TIP in, the hose going from Boost control module wasn't long enough. I found another piece of hose that was long enough but the inside of the tube was a little bit smaller than the stock piece. Maybe that could be the problem?
