brake lights
open trunk.
remove liner (removing all the round plastic clips and overlapping liner pieces until you can remove side sections) to access the space behind the tail lights, access is pretty straight foward; you twist the plastic bulb housing to unlock and remove bulb (outside corners).
if it is the inside section of the tailight, remove liner from under the truck lid to access bulbs; remove the same way as the above.
gl.post if u have more Qs.
