The valve itself I couldn't be happier with. It has amazing build quality. When I held the plastic valve to the piece, I was actually kind of pissed at mazda for releasing such a poor OEM part. I tore it up a bit last night with the valve. I used to peak at 15 and then drop to 11 immediately, which would then dissipate quickly. With the valve, I peak at 16, and it drops to 13-14, which it then holds... and holds... and holds.
I was out on route bumblefuck around here, turned off the dsc, and hit the gas in 2nd on a rolling start. The boost was outrageous, and I have not gone that fast in this car before (I hadn't had DSC off either though). It was like hitting light speed, I was pushed back so hard, the wheel was torquing, sustained boost at 14 psi... crazy. Now my fuel trims are kloogy though, I may need to reset the ECU to train it properly, unless it does better on the way to work.
The thing I want to stress about this valve is its ability to be 100% BPV or 100% VTA. I currently have it set "hard" which I will get into more later as far as the metrics, but it definitely sounds beast. The sound of BOV with the safety of recirc, that's why I was intrigued. Plus DaleNixon made me do it, since he has a forge, and we wanted to compare the two.
So in a way, my sheared bolt was really DaleNixon's fault
Plus I wasn't FORCING the damn thing. It was turning nicely and then SNAP. I think they cut corners with these bolts man, it's like they're aluminum.
