boost guage installed!
mtbjedi said:
Where did you get the brushed bezel rings? Were they easy to install?
search for member daveb he makes them 30 dollars not bad and very easy to install :) infact i have install instruction on my website
http://r-gfx.net look at how to remove guage cluster
i always slip at launch i never drop it. drop in this car produces wheel hope its much better for me anyways when i dragged the first time i dropped it wheel hopped like a mother at 6-7 psi but when i slipped i launched with minmal wheel spin. i slip into a drop i should say, i slip just a lil past the give point on the clutch then when it start i drop the clutch and punch it with a lil ease not just slamming it to the metal after first gear i slam to the metal tho.
haha. 12 second as in it only lasted 12 second b4 it blew up or 12 second 1/4 mile? LMFAO
i used to have to do 8k RPM clutch drops in my Integra...that was on slicks and pulled 1.75 60 foots :)
Speaking of wheel hop!Does anyone know if the AWR motor mounts help with the excessive wheel hop that the MSP's produce on launch?:confused:
you wont wheel hope if you slip the clutch to the give point then drop it.
okay i found the best way to keep the pod down, i tried silicon didn't work that well becuz there is to much of a gap between the column and were the pod touches, so i tried velcro thinking it would hold it down nope didn't work, so is what i did was i got some double stick tape squares at walmart adn stacked them 4 high on the white column peice worked perfect no rubbing and is pretty sturdy. and with it being double stick tape i could tak eit off at anytime and replace them :)
no techincally you shouldn't if you launch at the right rpm's but drop it at around 3 - 4 k and see if you dont wheel hope ;)
Ah bEgora!
Logan said:
Um, I've never had wheel hop in my car...
check your tire pressures
Oh yes the beotch do hop like a River Dancer on Speed.
Just strap on some black tights and shiny shoes to my MSP because baby it be a river dancing.
It can be controlled but I wish we could totally eliminate it.
Re: Ah bEgora!
come one and all men and woman of all ages boys and girls come see the famous riverdancing msp WOot
For what it is worth, check out the Forced Induction section. Most of those guys are adding AWR motor mounts and they claim they help tremendously with wheel hop.
