Bc coilovers
raul_gianino
2003 Mazda Protege5
Okay I've had my coilovers for about 3 months now and about a week ago I adjusted the height I had no problem adjusting the height except for the rear. I by mistakingly loosened the spring on top but I called bc and they helped me preload them again. No problem. I'm sitting where I want to sit.
But then this noise came up , only coming from the rear passenger side. It only makes the noise when I'm in parking lots or going over bumps in my complex. So I'm guessing when it compresses and decompressed. I have no idea what it could be. Everything is tightened.
Any ideas on this ? Has it happened to anyone before ?
How low are you? If you're quite low, you might be rubbing. Do you have your fenders rolled?
I'm maxed out in the front but in the back there's plenty of space. It's not rubbing I've checked it out. I tightened the springs and the noise kinda went away but it's still there driving around my complex
I only hear it at low speeds. Could it be the damper control ? Or that something is loose on top ?
