Advice on this stunning light display (2015 CX-5)
Are actual code numbers available from your device? I couldn't tell you much based on that screenshot.
Did you try to clean the battery leads and posts? Look at the positive cable. There are a bunch of fuses inside. Maybe one of them is blown.
so i managed to clear all but 2 codes belonging to same issue. I cant delete them for some reason so I assume (hopefully) that the issue is with this.
U053B:82-0A and U053B:83-0A
Maybe the issue with this has a knock on effect to all the other errors.
I am also assuming that all the other faults are going to come back after a drive cycle.
