4 lug rear drum 2 5 lug rear disc
Maz2001MP
Contributor
i want 2 convert this on my 2001 lx 2.0... someone on this site is selling the rear disc and spindles.. what else would i need for the rear .. and while im hear i need 2 convert the front 2 a 5 lug... what about that>>? im doing this mainly because in the future i plan on doing the big brake kit up front and they only make it for the ES... btw the rear disc are from a pro5
yes i would be able to purchase both rear discs and spindles from a pro 5 for $100 plus shipping.... I was just wondering what other parts I would need to make the rear disc conversion complete (im guessing calipers, brake lines, etc.) and if the pro 5 rear discs will fit on my 2001 lx 2.0... i also plan on doing a 5 lug conversion to the front end... but i once i have all pieces I will do it all at once... if anybody has any info i would appreciate it.. thanks
hey Maz2001MP
I happen to have the whole set that you need for the rear conversion. I have the spindles,calipers with brake pads and disc brakes for the front and back from a ES 2001 protege not a Prote-5 so you know it will fit. it had 11k when i rmoved them so they are practically new. I even have the 4 struts with 11k miles also if you need them. they are tokikos in black(this are the originals for the proteges but are not the blue ones from the MP3)
i can sell you the complete rear set with hoses and all for $120 plus shipping and if you would also like the front ones then i can do a nice package for $180. This would include calipers with brake pads,disc brakes, hoses,spindles and even the Chrome lug nuts :p. let me know
P.S the rear disc brakes are from a 2001 MP3 which are a bit thicker and better than the regular proteges.also i have the brake booster with the pump if you need it.
Best luck
Green
Re: hey Maz2001MP
uhh no... the mp3 brakes are EXACTLY the same as the ES and P5's not thicker, not grabbier... EXACTLY the same
and upgrading the brake booster and master cylinder as well as using the correct proportioning valve IS needed
Best luck
Green
Man as i told you before you do not know it all and here is the proof
SPECIFICATIONS
MP3
ENGINE AND ELECTRICAL
Engine Type-FSD
2.0L DOHC 16-valve I4
Horsepower, SAE net
140 @ 6000 rpm
Torque lb. ft., SAE net
142 @ 4500 rpm
Redline
6,500rpm
Displacement
1991 cc/121.4cu. in.
Bore x Stroke
83 x 92 mm/3.26 x 3.62 inch
Compression Ratio
9.1:1
Turning Circle, Curb-to-Curb
10.4m/34.1ft.
Braking System
Power assist (4-wheel, 4-sensor)
Front Brakes
Ventilated discs ( 10.2 x 0.9in.)
Rear Brakes
Solid discs ( 10.3 x 0.9in.)
Parking Brake
Mechanical, hand-operated on rear wheels
CHASSIS
Rear Brakes
here is the info on a regular protege
DX, LX SHARED ES
Engine Type Type-FSD 2.0-liter DOHC 16-valve I4
Horsepower, SAE net 130 @ 6000 rpm
Torque, SAE net 135 @ 4000 rpm
Redline 6,500 RPM
Displacement (ml/cc) 121.4
Bore x Stroke (mm / in) 3.26 x 3.62
Compression Ratio 9.1:1
Body Type 5-passenger, 4-door sedan; monocoque unit
Front Suspension Independent, MacPherson strut, coil springs and stabilizer bar
Rear Suspension Independent, strut with Twin-Trapezoidal Link (TTL), coil springs and stabilizer bar
Shock Absorbers Telescopic, double acting
Steering Type Rack-and-pinion
Power Assist Engine-rpm sensitive; variable power-assist
Overall Steering Ratio 15.0:1
Steering Wheel Turns-to-Lock 2.7
Turning Circle, Curb-to-Curb (feet) 34.1
Braking System Power assist (4-wheel, 4-sensor, 3-channel ABS option on LX & ES)
Front Brakes Ventilated discs (10.2 x 0.9 inches)
Rear Brakes Drums (7.9 x 1.4 inches) Solid discs (10.3 x 0.4
Again you stuck your nose where it wasn't called and you were wrong.
Sometimes it's better to think before you open your mouth.
Green(moon)
gee... the part number looks awefully familiar... I wonder what it is :rolleyes:
Damn, Edwin was accually civil with this one....Just think if it had been back in the day a PClub. :eek:
OWN YOURSELF
You mean to tell me that you have never had problems before at the dealer where even with the Mazda parts software they cannot either find you the right part or they just cross over it to the next close thing > In the MP3 case is the Protege ES Ofcourse.
I know this cause at the dealer they tell me that the MP3 has the same rack and pinion as the ES(NOT!) and also they tell me that the MP3 badges can"t be obtain and things of that nature. Just cause you have the software it does not make you been correct.
I gave the website of that guy cause he is one of the few that still has the specs from the 2001 MP3. He had them posted in that same year and he did not made a typo mistake cause he copy the whole thing from the Mazda Website and ofcourse every magazine that has published this specs also wrotte the same thing so hummm, somebody here must be mistaken, i wonder who???
Mazda has some parts that they cannot get for the MP3 only that this they will not say out loud, i know believe me i've been there.
so they just kinda get you the same one for both cars. or sometimes they just give you an MP3 part for your ES like in the case you stated at the pictures. If you read carefully you will see where it reads ( SPORT SUSP). And you and I know that only the MP3 has that suspension. I agree that the parts software showed the same part number but manufactors do that all the time to save money in just standarding some parts since they both fit the same car, BUT that does not mean that the cars didn't come with different specs from the factory line. specially if they stated in the spec spread sheet of each car.
Any how this is a Mazda manufactor problem not mine, all i know is that they (MAZDA) say so and i believe them more than you THE MAN so you can believe your parts outdated software or the spec sheet, either way it won't change or do anything for me Cause I Got BREMBO rotors and i know you are not gonna question those since we both know that they are much better.
Respectfully
GREEN!
TheMAN is absolutely correct. All of the brake parts are IDENTICAL on the MP3, P5, and ES from 2001+. There is no way in hell that a non-vented rotor is going to be 0.9" thick. That would be plain stupid.
Here's an example. The rear rotors on my 3/4 ton pickup truck are 1.18 inches thick and 13.9 inches in diameter. There is no way that a Protege MP3 has 0.9 inch rear rotors.
