225/45/18 on stock rims?
11 MS3 Sport
Stock tire size: 215/45/18
Step up size: 225/40/18
What if I were to get 225/45/18? Any ill-effects? I'm running stock MS3 wheels with the hopeful intention of upgrading to a 18x8 wheel eventually. The Tire Rack opportunity is too hard to pass up!
Ive got 225/40/18,
1 because it is a more common tire size so more options at less cost.
2. I did hear that some people had some issues with the tire rubbing. (but those might have been fat people)
O.K. I just pasted this here from another thread I replied to, this is why I won't run a 225/40 on a stock MS3 wheel..."When you combine the width/aspect ratio you get the bead of a cross-ply tire. It consists of bundles of bronze coated high tensile strength steel wire strands which are insulated with rubber. A cross-ply tire designed for off-road use typically has two or three bundles. A radial on-road tire normally only has one. The bead is considered the foundation of the tire. It anchors the bead on the rim. That's why you just can't look at the numbers individually, they need to be looked at together to determine the appropriate size wheel. Look at the link and plug in the 225-40-18, minimum width rim is 7.5", now plug in the 225-45 minimum is 7". I know people run this 225-40 I for one won't take a chance on that size on the stock wheel. My tires are the first thing between me and the road...nobody in the tire service industry will recommend a 225-40-18 on a 7" wide wheel, there's a reason for that"...
The link I was referring to was Tire Rack. If you go to Tire Rack or any other tire seller plug in the numbers and you'll see no one recommends a 225/40/18 on a 7" rim, period.
Hehe lemme guess, your'e looking at buying a set of Potenza RE01-Rs? Check out the other thread to that... I'm too lazy to post the link but it's right under - MS3 rims tires ect.
