2025 CX-5 PP Understanding Traffic Jam Assist (TJA)
CX-5 2025 PP
CX-5 2017 GT
CX-5 2014 GT
Its pretty clear to me I do not understand TJA and am more confused after reading the manual. My understanding is that this functionality works with i-Activesense in traffic jams.
This is my experience. When cruise control is inactive with no white or green MRCC icon displayed the TJA amber icon will appear between the lane assist lines in the HUD, if I begin to drift toward the edge of the lane. If I drift a little further the lane assist alert will go off. The amber TJA icon appears in the HUD, between the lane assist lines, as the car drifts toward the lane edge with no traffic, while traveling 70mph, perfect weather. It almost appears to be a pre-alert that I am drifting toward the edge of the lane. No cars anywhere in sight traveling at highway speeds. The manual states this functionality is for traffic jams?
The manual states: For the purposes of safety, switch the TJA off when it is not being used. I dont see any way to turn TJA on/off. I dont have MRCC enabled. I have looked through settings. Also tried pressing the "mode on" button on the steering wheel multiple times to see if it would toggle between MRCC and TJA. How do I turn it on and off?
Perhaps the amber steering wheel between the lane assist lines in the HUD is NOT the TJA icon? If thats the case then what does that amber steering wheel icon indicate? It is NOT the amber steering wheel with the (!) that indicates a problem with power steering.
After reading further I think what I am seeing is steering wheel operation assist:
Steering Wheel Operation Assist When the system determines that the vehicle might be deviating from its lane, the steering wheel operation assist operates. The system notifies (amber) the driver that it provided steering wheel operation assistance on the multi-information display and the active driving display.
I don't think that's the Traffic Jam Assist. My understanding of TJA is as follows.
TJA consists of headway control plus steering assist using radar and the forward camera. It requires a lead vehicle and operates slightly differently depending on whether lane lines are detected. It is meant for expressways or highways only. The manual says to not use it on "general roads" but I am not sure if this is a technical limitation or merely a liability issue.
It will use the lane lines and the car in front of you to basically autopilot with lane centering. That's why there is a little steering wheel icon called "Steering Assist" and it will be green in these conditions. If no lane lines are detected, it will just use the car ahead to keep the vehicle "along the motion path".
When a lead vehicle is not detected, according to the manual, the steering assist is inactive (steering wheel icon is white) and it is just regular radar cruise.
Finally, it will not operate over 35 mph (56 km/h).
Relevant section: https://www.mazdausa.com/static/manuals/2023/cx-5/contents/05283703.html
I believe you are correct, since the icon is used for multiple functionality I believe I have confused TJA steering wheel assist with "Steering Wheel Operation Assist". It appears to me the only way to tell the functionality being used is by the difference in the color of the icon. Amber for Steering Wheel Operation Assist and White or Green for TJA steering wheel assist.
For up to 2025 - TJA is full steering wheel control up to 39mph. the steering wheel icon turns green. car keeps you centered. It also works with MRCC to full stop if needed. It is the full control but mazda limited it to 39mph for North America. Only Signature trims from 2022-2025 have it. Its separate button to enable.
Lane assist is the slight nudge with orange icon. All trims have it.
