2021 CX-5 Signature Connecter Identification
Hi everyone,
This connector is for the dome light in my 2021 Mazda CX-5 Signature Edition. I want to use this connector to add an accessory without modifying or splicing into the stock wiring harness. To do this, I need both the male and female connectors to create a clean, plug-and-play solution.
I have the wiring diagrams, but I’m struggling to use them to find the part numbers for this connector. Unfortunately, the connector itself doesn’t have any identification numbers on it. I’m open to purchasing from any source, but I really need help identifying the correct part number.
I've linked pictures below—if anyone has experience sourcing Mazda connectors or knows how to track down part numbers for these, I’d greatly appreciate your help! Any advice on where to look or who to contact would be super helpful. Thanks!
Thank you
isnt it easier just to plugin into the rearview mirror connector?
you have homelink and it has 12V and ground.
lots of info here which wire to use. You can even buy premade plugs and even usb out.
The reason i am using the dome light is so that it turns on when the dome lights are on. i am not installing a dash cam. i am installing puddle lights
