2003 MSP 2.0t unichip map help please
Joe P
Jerry's MSP
This is a good friends car I'm attempting to sort. Bad, pig rich transition from closed loop, light load to open loop spooling. Translates as a bad hesitation and having to keep in it to drive through it and make power. No real mods to speak of, still draw through as well. IF you catch it before it goes into closed loop, power and response is pretty good.
Ended up choosing a unichip pnp for it. Set it up and the base map that came with it has the MAF readings at 236 at idle, normal should be in the 4's.
I'm looking for someone with a working base map to tune off of. I'm a Benz guy so this is a entirely new experience for me but, I've gotten the needed software and such I just need a working baseline map to work off of if possible for this pnp.
Thanks
