2 different squeaks and clunk?
Mazda Pro
2003 Mazdaspeed Protege 2.0 Turbo
New timing,drive, and sterring belt starting to squell sometimes mostly at night and early morning. Sprayed sway bushing with wd40 squeaks alot less still there and a clunk back seat area. Can it be trailing arms and sway bushing and a crank pulley? I looked hard all over fourm cant find my answer
Tighten up your belts. The clunk is probably your end links. The squeak will go away if you replace your bushings and grease them up.
Fixed thx alot man ******* course only dealer has thoes bushing. Didnt want poly for a daily protege The squealing belts are new and tight comes and gos not long tho maybe The groves and ten
if the belts are making noise only when cold, or very humid outside...its probably just the tension. If they are making noise all the time, its one of the idlers/pulleys somewhere.
the belts will 'settle' in when new...you'll often have to adjust the tension after a few hundred miles. The PS/AC belt is very simple and easy to reach, the water pump/alternator is in a trickier location, but still very easy if you just installed new belts. I would suggest tightening them a few turns more on the respective adjuster screws (the big long bolts you have to loosen to remove the belts) and see if that helps. No need for concern if the noise quickly goes away after they heat up a little; thats commonly a tension issue...but like i said, if they are binding up somewhere and that is whats causing the slipping...it could be one of the accessories itself.
