Bump!
Is the 2000 626 1.8 valve cover really needed? How much tinkering will I have to do with my 2.0 valve cover?
Also, if I do go to the wreckers to pick up a 626 valve cover, is the gasket different from the 2.0 gasket?
the cam cover makes everything fit back together the way it was designed. you CAN reuse the 2.0 protege cam cover, but you will have to modify the plug wires to fit down onto the plugs. the 2.0 cover sits ever-so-slightly higher than the 1.8 above the plugs. i was getting random misfires on my set-up before i was able to find the proper cover.
gaskets swap over, but they are also a low cost part. i changed mine out when i did the conversion for peace of mind.
