07 mazda5 Spark Plug torque specs
'07 Mazda5 GT
Hello. Will be replacing my spark plugs soon on my '07 MZ5 GT. Already got the spark plugs from a local Mazda dealer. I need to know torque and gap specs on the spark plugs. Anyone have the info available? TIA.
SPARK PLUG REMOVAL/INSTALLATION [L8, LF]
DPE011818110W01
Caution
• If a spark plug that is not as specified is installed, sealing performance will be deteriorated. Install
only the specified spark plug when replacing.
1. Remove the battery cover. (See 01–17A–1 BATTERY REMOVAL/INSTALLATION [L8, LF].)
2. Disconnect the negative battery cable.
3. Remove the plug hole plate. (See 01–10A–2 PLUG HOLE PLATE REMOVAL/INSTALLATION [L8, LF].)
4. Remove the ignition coil. (See 01–18–1 IGNITION COIL REMOVAL/INSTALLATION [L8, LF].)
5. Remove the spark plugs using a plug-wrench.
6. Install in the reverse order of removal.
Tightening torque
10—14 Nm {1.1—1.4 kgfm, 8—10 ftlbf}
End Of Sie
SPARK PLUG INSPECTION [L8, LF]
DPE011818110W02
Specification
Spark plug type
L303 18 110
Plug Gap Inspection
Caution
• To avoid possible damage to the tip, do not adjust the plug gap.
• To prevent damaging the tip, use wire type plug gap gauge when inspecting the plug gap.
1. Measure the spark plug gap using the wire type plug gap gauge.
• If it exceeds the specification, replace the spark plug.
Spark plug gap
1.25—1.35 mm {0.049—0.053 in}
DPE011818110W01
Caution
Tightening torque
End Of Sie
DPE011818110W02
Specification
Spark plug type
L303 18 110
Plug Gap Inspection
Caution
Spark plug gap
https://www.dropbox.com/s/btplevswx1hn1qb/WM_01.pdf
Page 317
